Our client purchased the UniFi AP Pro AP’s two of them and configured using the configuration controller software, Required to push out a configuration for both AP’s - these are both wired back to the switch. By default, the wireless endpoint will hand off from AP 1 to AP2 correct? No need for fully transparent using a Radius but just hand off when AP 2 offers a stronger signal. No extra options they need to click to make that happen correct?
Chat started
(Reseller)
**Q: **
**UniFi AP Pro using your config software - handoff from AP 1 to AP 2 - possible out of the box policy pretty much or anything special needed?
No need for transparent such as using a Radius Server, it is a home user, the stronger signal on AP2 will hand off from AP1 when roaming around the house would be an example.
A:
If the same SSID is configured on both the APs then by default roaming is enabled on the APs no need for Radius configuration
