Block malware and phishing attacks
and increase your email deliverability!
Prevent brand abuse, scams and gain full insight into your email channel with DMARC Analyzer
(use Default then Domain for DKIM Check)
SPF, DKIM, and DMARC checker Tools
DMARC Generator Tool
https://mxtoolbox.com/DMARCRecordGenerator.aspx
In order to implement DMARC you need a valid DMARC record. At DMARC Analyzer we provide a free to use tool called DMARC Record Check to display your DMARC record, test it and verify whether it’s valid. DMARC Record Check is free and easy to use. To perform a DMARC check you will only need to provide your domain name. The DMARC Record Check will then parse your DMARC record and displays the DMARC record along with additional information.
Use DMARC Record Check to test and lookup your DMARC record. You can evaluate each possible option and the ones you’ve implemented. DMARC Record Check will also verify and test if you are using external domains.
DKIM (DomainKeys Identified Mail) is an email authentication technique that allows the receiver to check that an email was indeed sent and authorized by the owner of that domain. It works together with DMARC (and SPF).Read more about this topic in our article about DKIM signature
In order to implement DKIM you’ll need to have a valid DKIM record. You can use a DKIM Checker to check your DKIM record. A DKIM Checker or DKIM Analyzer tool will test the domain name and selector for a valid published DKIM record. DKIM authenticates the reputation and identity of the sender. We strongly recommend you to carefully test any updates to your DKIM records before applying them.
In order to implement SPF you will need to have a valid SPF record. DMARC Analyzer provides a SPF Record Checker to validate your SPF record.
We can also pre-validate an update you intend to apply to your record to prevent issues popping up after the update was done. We recommend you to carefully test any updates to your SPF records before applying them.
What is DMARC?
DMARC is an email-validation system. DMARC was created by PayPal together with Google, Microsoft and Yahoo!. With DMARC an organisation gains insight and control over the email channel. Organisations can use DMARC to protect their brands against abuse in phishing or spoofing attacks. Learn more…
DMARC empowers organisations to:
- Gain full visibility and governance across all email channels
- Authenticate email messages and improve deliverability
- Block inbound attacks and protect their brands against abuse
- Publish a policy that instruct ISP’s to deliver or delete emails
