SonicWALL TZ 215 Specs
Firewall SonicOS Version: 5.8.1 and later
Stateful Throughput: 500 Mbps
IPS Throughput: 110 Mbps
GAV Throughput: 70 Mbps
UTM Throughput: 60 Mbps
Maximum Connections: 48,000
Maximum UTM/DPI Connections: 48,000
New Connections/sec: 1,800
Nodes Supported: Unrestricted
Denial of Service Attack Protection: 22 classes of DoS, DDoS, and scanning attacks
SonicPoints Supported: 16
VPN 3DES/AES Throughput: 130 Mbps
Site-to-site VPN Tunnels: 20
Bundled GVC Licenses (Maximum): 2 (25)
Bundled SSL VPN Licenses (Maximum): 2 (25)
Encryption/Authentication/DH Group: DES, 3DES, AES (128, 142, 256-bit), MD5, SHA-1, SHA-2/DH Group 1, 2, 5, 14
Virtual Assist Bundled (Maximum): 2 (30-day trial)
Key Exchange: IKE, Manual Key, Certificates (X.509), L2TP over IPSec
Certificate Support: Verisign, Thawte, Cybertrust, RSA Keon, Entrust and Microsoft CA for Dell SonicWALL-to-Dell SonicWALL VPN, SCEP
VPN Features: Dead Peer Detection, DHCP Over VPN, IPSec NAT Traversal, Redundant VPN Gateway, Route-based VPN
Global VPN Client Platforms Supported: Microsoft Windows XP, Vista 32/64-bit, Windows 7 32/64-bit
SSL VPN Platforms: Microsoft Windows XP/Vista (32/64-bit)/Windows 7, Mac OS X 10.4+, Linux FC3+/Ubuntu 7+/OpenSUSE
Mobile Connect Platform Supported: Apple iOS 4.2 or higher, Google Android 4.0, or higher
Security Deep Packet Inspection Services: Gateway Anti-Virus, Anti-Spyware, Intrusion Prevention, Application Intelligence and Control
Content Filtering Service (CFS): HTTP URL, HTTPS IP, keyword and content scanning, ActiveX, Java Applet, and cookie blocking bandwidth management on filtering categories, allow/forbid lists
Enforced Client Anti-Virus and Anti-Spyware: McAfee
Comprehensive Anti-Spam Service: Supported
Application Intelligence and Control: Application Traffic Visualization and Advanced Application Control
Networking IP Address Assignment: Static, (DHCP, PPPoE, L2TP and PPTP client), Internal DHCP server, DHCP relay
NAT Modes: 1:1, 1:many, many:1, many:many, flexible NAT (overlapping IPs), PAT, transparent mode
VLANS: 20, PortShield
DHCP: Internal server, relay
Routing: OSPF, RIP v1/v2, static routes, policy-based routing, multicast
Authentication: LDAP, Local DB, RADIUS, XAUTH, X-Forwarders
SSO: AD, eDirectory, RADIUS Accounting, NTLM, X-Forwarders, Terminal Server and Citrix
Local User Database: 150 users
VoIP: Full H.323v1-5, SIP, gatekeeper support, outbound bandwidth management, VoIP over WLAN, deep inspection security, full interoperability with most VoIP gateway and communications devices
System Zone Security: Yes
Schedules: Yes
Object-/Group-based Management: Yes
Dynamic DNS Providers Include: dyndns.org, yi.org, no-ip.com and changeip.com
Management and Monitoring: Local CLI, Web GUI (HTTP, HTTPS), SNMP v3; Global management with Dell SonicWALL GMS
Logging and Reporting: Analyzer, Scrutinizer, GMS, Local Log, Syslog, Solera Networks, NetFlow v5/v9, IPFIX with Extensions, Real-time Visualization
Hardware Fail Over: Active/Passive
Anti-spam: RBL support, Allowed/Blocked Lists, Optional Dell SonicWALL Comprehensive Anti-Spam Service
Load Balancing: Yes, Outgoing and Incoming
Standard: TCP/IP, UDP, ICMP, HTTP, HTTPS, IPSec, ISAKMP/IKE, SNMP, DHCP, PPPoE, L2TP, PPTP, RADIUS, IEEE 802.3
WAN acceleration support: Yes, with Dell SonicWALL WXA appliances
Wireless LAN Not available
Hardware Interfaces: 7 x 10/100/1000 copper gigabit, 2 x USB, 1 x console
Processor: Dual-core
Flash Memory/RAM: 32 MB/512 MB
3G Wireless/Modem: Supported with approved adapters
USB Ports: 2
Power Input: 100 to 240 VAC, 50-60 Hz, 1 A
Max Power Consumption: 9.0 W/12.0 W
Total Heat Dissipation: 30.6 BTU/41.4 BTU
Certifications: VPNC, ICSA Firewall 4.1 Common Criteria NDPP, IPv6 Phase 2
Certifications Pending: EAL4+, FIPS 140-2 Level 2
Major Regulatory Compliance: FCC Class A, CES Class A, CE, C-Tick, VCCI, Compliance MIC, NOM, UL, cUL, TUV/GS, CB, NOM, WEEE, RoHS
MTBF: 28 years/15 years
Temperature: 32 to 104°F / 0 to 40°C
humidity: 5 to 95% non-condensing
Dimensions 7.1 x 1.5 x 10.5" / 18.1 x 3.8 x 26.7 cm
Weight 2.0 lb / 0.9 kg
2.2 lb / 1.0 kg
Packaging Info
Package Weight | 4.65 lb |
Box Dimensions (LxWxH) | 18 x 10.5 x 3" |
