SonicWALL NSA 220 Technical Specifications
Dell SonicWALL NSA 220 is End of Life and no longer sold.
Also the spec’s are no longer published - below are the specs before it was EOL
Upgrade your SonicWALL Solution at http://www.SonicGuard.com
Tech Specs
Specifications are provided by the manufacturer. Refer to the manufacturer for an explanation of the print speed and other ratings.
Capacity
Type: Connection / user qty
Value: 85000
Type: DPI connections
Value: 32000
Type: New sessions per second
Value: 2200
Type: Authenticated users (internal database)
Value: 100
Card Reader
Supported Flash Memory Cards: CompactFlash Card
Dimensions & Weight
Depth: 7.1 in
Height: 1.5 in
Weight: 1.94 lbs
Width: 10.5 in
Environmental Parameters
Humidity Range Operating: 5 - 95% (non-condensing)
Max Operating Temperature: 104 °F
Min Operating Temperature: 32 °F
Flash Memory
Installed Size: 32 MB
Header
Brand: Dell SonicWALL
Compatibility: PC
Manufacturer: SonicWALL
Model: 220 TotalSecure
Packaged Quantity: 1
Product Line: Dell SonicWALL NSA
Interface Provided
Connector Type: RJ-45
Qty: 7
Type: 1000Base-T
Qty: 1
Type: Management
Connector Type: Type A
Qty: 2
Type: USB
IP Telephony
IP Telephony Features: VoIP gatekeeper support , VoIP outbound bandwidth management
VoIP: Yes
VoIP Protocols: H.323 v1 , H.323 v2 , H.323 v3 , H.323 v4 , H.323 v5 , SIP
Miscellaneous
Authentication Method: Active Directory , Internal user database , LDAP , RADIUS , Secure Shell (SSH) , X.509 certificates , XAUTH authentication
Compliant Standards: C-Tick , CB , cUL , EAL 4+ , FCC Class A certified , FIPS 140-2 , MIC , NOM , RoHS , TUV GS , UL , VCCI , WEEE
Encryption Algorithm: 128-bit AES , 192-bit AES , 256-bit AES , DES , IKE , MD5 , PKI , SHA-1 , Triple DES
Height (Rack Units): 1
MTBF: 28 year(s)
Networking
Compliant Standards: IEEE 802.1p , IEEE 802.1Q , IEEE 802.3 , X.509
Connectivity Technology: Wired
Data Link Protocol: Ethernet , Fast Ethernet , Gigabit Ethernet
Data Transfer Rate: 1 Gbps
Features: Anti-spam protection , Antivirus analysis , Content filtering , DDos attack prevention , Dead Peer Detection (DPD) , Deep Packet Inspection (DPI) , DHCP server , DHCP support , DoS attack prevention , Dynamic DNS server , Firewall protection , High Availability , Intrusion Prevention System (IPS) , IPSec NAT-Traversal (NAT-T) , IPv6 support , Load balancing , Quality of Service (QoS) , Stateful Failover , Syslog support , VPN support
Form Factor: External
Network Transport Protocol: DHCP , ICMP/IP , IPSec , L2TP , PPPoE , PPTP , TCP/IP , UDP/IP
Ports Qty: 7
Remote Management Protocol: HTTP , HTTPS , SNMP 2 , SSH
Routing Protocol: OSPF , Policy-based routing (PBR) , RIP-1 , RIP-2 , Static IP routing
Type: Security appliance
OS Provided
Type: SonicOS
Performance
Type: Stateful throughput
Value: 600 Mbps
Type: Gateway anti-virus throughput
Value: 115 Mbps
Type: IPS throughput
Value: 195 Mbps
Type: Full Deep Packet Inspection (DPI) throughput
Value: 110 Mbps
Type: Firewall throughput (IMIX)
Value: 180 Mbps
Type: VPN throughput (3DES/AES)
Value: 150 Mbps
Power Device
Frequency Required: 50/60 Hz
Nominal Voltage: AC 120/230 V
Power Consumption Operational: 11 Watt
Power Provided: 36 Watt
Type: Internal power supply
RAM
Installed Size: 512 MB
Service & Support
Bundled Services: 1 year GAV/AS/IPS/Application Intelligence Service/Content Filtering Service and Dynamic Support 24X7
Business Grade Hosting - World Wide
Liquid Layer Web Hosting
http://www.LiquidLayer.net
ParagonHost
http://www.ParagonHost.net
