SonicOS 6.5 Quick Configuration Guides May 2019 Wizards
https://www.sonicwall.com/support/technical-documentation/sonicos-6-5-nsv-quick-configuration.pdf
SonicOS 6.5 for NSv Series Quick ConfigurationUsing SonicWall QUICK CONFIGURATION Guides13Using SonicWall QUICK CONFIGURATIONGuides•
About the QUICK CONFIGURATION Guides on page 3•Configuring a Static IP Address with NAT Enabled on page 3•Launching the Guides on page 4•Navigating through the Guides on page 4About the QUICK CONFIGURATION Guides SonicOS provides easy-to-use configuration guides to assist you with initial policy and security creation:•Securing your internet connection•Providing public access to an external server•Creating site-to-site VPN policies•Configuring App Rules for security Topics: •Configuring a Static IP Address with NAT Enabled on page 3•Launching the Guides on page 4•Navigating through the Guides on page 4
Configuring a Static IP Address with NAT EnabledUsing NAT to set up your SonicWall eliminates the need for public IP addresses for all computers on your LAN. It is a way to conserve IP addresses available from the pool of IPv4 addresses for the Internet. NAT also allows you to conceal the addressing scheme of your network. If you do not have enough individual IP addresses for all computers on your network, you can use NAT for your network configuration. Essentially, NAT translates the IP addresses in one network into those for a different network. As a form of packet filtering for security appliances, it protects a network from outside intrusion from hackers by replacing the internal (LAN) IP address on packets passing through a SonicWall with a “fake” one from a fixed pool of addresses.
The actual IP addresses of computers on the LAN are hidden from outside view.
