WebWhip Wi-Fi Reciver
PRODUCT ID: ZZ38974 MFG ID: WIFI-1
Stay connected to the world of information where ever you go. Increase the coverage of public hotspots with the WebWhip, our fully integrated Wi-Fi antenna, radio and router, for hassle-free internet reception on your boat, RV, cabin or AnyWhere® else. Access the internet directly through LAN or wirelessly, by connecting WebWhip to any standard Wi-Fi router. Manage the network without any software installation through any device with a web browser. Simple, powerful, AnyWhere.
Range: Up to 7 Miles
Power Supply & Consumption: 12VDC & 120/220VAC, 0.6A at 12VDC
Dimensions: 19.5in x 3.1in x 1.5in (24.13cm x 7.87cm x 3.81cm)
Wireless Approvals: FCC Part 15.247, IC RS210, CE
Frequency and Wireless Standards: 2.4GHz, 802.11 b/g/n
28dBm Receiver
Built-in Router
Works with normal Wi-Fi router
Power over Ethernet (PoE)
Fully Plug and Play
Web-based device manager
FCC certified radio
Benefits
Long range WiFi reception on land or water
Connect straight to your computer without separate router
Easy to create local Wi-Fi hotspot with any standard Wi-Fi router
Single wire for power and data. No power consumed from connected device
Simple, intuitive set-up and operation. No software installation required
Manage device easily on any device with an internet browser
Safe and legal
Radio Power: Up to 28dBm
Antenna Gain: 5dB
Range: Up to 7 Miles*
Throughput: 100+ Mbps
Wire: 25ft (7.62m) Ethernet cable
Connectors: N-Female (Antenna), Ethernet (Device)
Power Supply & Consumption: 12VDC & 110/220VAC, 600mA at Max 12VDC
RoHS Compliant: Yes
Dimensions: 19.5in x 3.1in x 1.5in (49.53cm x 7.87cm x 3.81cm)
Kit Weight: 38.8oz (1099.9g)
FCC ID (USA): SWX-M2B
Click the below URL for Product Detail and Purchase:
https://www.starmarinedepot.com/shakespeare-wifi-1-webwhip-wi-fi-receiver/pzz38974.html
Curated by:
