https://winegard.com/products/wifi/extenders/connect-wifi-mobile/connect-wf1-black
ConnecT WF1 WiFi Extender for RVs - Black (WF-3035)
The Winegard ConnecT provides faster speeds and increased range from WiFi sources. Turn ‘WiFi Dead Zones’ into entertainment zones with a secure connection at the fastest speed available. Keep mobile devices, media players, and computers connected to WiFi with a reliable connection and expanded coverage.
Extended RV WiFi Range – Powerful amplifier and three high performance external antennas expand your WiFi coverage to receive signals inside your RV from farther away. Multi-user mimo-ready for faster performance for each device.
Secure RV Internet – Advanced WiFi protected access (WPA and WPA2-PSK), guest network access, double firewall protection (SPI and NAT), and denial-of-service (DoS) attack prevention.
Simple Setup – Connect all of your devices instantly when you connect to a new network. Easy step-by-step on screen instructions make setup a breeze. Set up your secure network once and you are done.
Proven Reliability – More powerful than your smartphone or hotspot device, the ConnecT dome design is rigorously tested to meet the demands of the mobile environment.
Reception Types: WiFi
Setup Requirements: Wireless 802.11a/b/g/n 2.4GHz network computer, tablet, or smartphone with a web browser
Wireless Standard: 802.11a/b/g/n/ac
Wireless Speed: 2.4GHz: 450Mbps (Rx), 450Mbps (Tx)
Wireless Speed: 5GHz: 1300Mbps (Rx), 1300Mbps (Tx)
Wireless Security: WPA, WPA2, WPA mixed
Ports: (1) RJ45 10/100/1000m Lan Port (IDU only)
Ports: (1) RJ45 PoE (ODU and IDU)
Ports: (2) USB 2.0 Ports
Power Rating: Switching, AC Input 100-240v, 1.5A
Frequency Band: 2.4GHz, 5GHz Simultaneous (5GHz indoor unit only)
Outdoor Amplifiers: (3) 2.4GHz amplifiers
Indoor Amplifiers: (3) 2.4GHz amplifiers, (3) 5GHz amplifiers
Outdoor Antennas: (3) Detachable high gain 5dBi antennas
Indoor Antennas: (3) Internal 2.4GHz 4dBi antennas, (3) Internal 5GHz 6dBi antennas
