As of Aug 17, 2015 - Advanced settings. The default password to enter the advanced settings is 23646. Accounts. The Accounts section contains parameters to allow the phone to register to a SIP server or. PBX. Contact your administrator before proceeding. The following fields can be configured: • Activation: enable or disable …
Advanced settings
Accounts
• Activation: enable or disable the account. Enabled accounts will try to register using the
configured settings.
• Label: the name of the account.
• Display Name: the caller ID that will be displayed when calling other phones. When
connected to a FortiVoice system, the caller ID information will be configured in the
FortiVoice web-based interface.
• Register Name: the user name used to authenticate with the SIP server or PBX.
• User Name: the phone number or extension number of the account.
• Password: the password used to authenticate with the SIP server or PBX.
• SIP server1: the IP address or FQDN of the SIP server or PBX.
• Outbound Status: enable or disable the use of an outbound proxy.
• Outbound Proxy: set the IP address or FQDN of the outbound proxy.
• STUN Status: enable or disable the use of a STUN server.
• STUN Server: set the IP address or FQDN of the STUN server.
• Auto Answer: the phone will automatically answer calls to this account if enabled.
Reset factory
The Reset factory section allows you to reset the phone’s configuration to factory default.
More info / see PDF below:
http://www.fortivoice.com/sites/default/files/productdatasheets/FON-470i_UG.pdf
