Can someone tell me why small clock battery flashing at small LCD ?
My D3 is brand new less than a month.
– hide signature –
James
Even though you may find that the time displayed is correct, part of the set up requires the user to go to the set up menu and set the time in order to make the little clock blinky go away. This was shock to several of use when we first picked up our D3’s in December (posted on this long ago).
James ,
You need to set the time in the menu see page 40 in the manual, see page 408 in the manual for the error message.
Regards,
Bruce.
my time is correct, so only change timezone, so to touch it…
Just remember to reset your Time Zone, Hour Min, Sec and Daylight Savings after you change the Battery. For some reason, at first I did not do this and thought there was a issue with the camera. Thankfully see the above link by way of the OP Response for the Manual for D5 and replacing Clock Battery.
