How to Remove Directories (Folders)
In Linux, you can remove/delete directories with the rmdir and rm .
rmdir is a command-line utility for deleting empty directories while with rm you can remove directories and their contents recursively.
- To remove an empty directory, use either
rmdirorrm -dfollowed by the directory name:
rm -d dirname
rmdir dirname
- To remove non-empty directories and all the files within them, use the
rmcommand with the-r(recursive) option:
rm -r dirname
If a directory or a file within the directory is write-protected, you will be prompted to confirm the deletion.
- To remove non-empty directories and all the files without being prompted, use
rmwith the-r(recursive) and-foptions:
rm -rf dirname
- To remove multiple directories at once, use the
rm -rcommand followed by the directory names separated by space.
rm -r dirname1 dirname2 dirname3
Same as with files you can also use a wildcard ( * ) and regular expansions to match multiple directories.
