HowTo: Use Fenced Code Blocks or Highlight Code
Jeff Atwood Mentions:
I would not recommend using fenced code blocks for things that “are not code.” Try indenting the lines by 4 spaces, or select the text and use the preformatted toolbar button, to insert 4 spaces before each line and indicate a preformatted block instead.
https://meta.discourse.org/t/confused-about-highlighting-in-code-blocks/8708
HostCheetah Mentions:
We do recommend using: insert 4 spaces before each line and indicate a preformatted block instead.
http://www.liquidlayer.net
https://meta.discourse.org/t/support-for-bbcode-code-blocks-with-syntax-highlighting/31891
BBCode code blocks work
This is a code block using BBCode
Composed as
This is a code block using BBCode BBCode code blocks work
Composed as
Above is by enclosing snippet using [ code ] and [ /code]
(no spaces, inside the brackets) spaces are used here to show the syntax.
