How to Resolve Configure: Error: no acceptable C compiler found in $PATH
- by Ed Chen
- August 5, 2017
Python Installation
Tried to install python 3.7.1 in Linux and met this error: “configure: error: no acceptable C compiler found in $PATH”. No doubt, this error will also appear in Ubuntu and CentOS.
First of all, I downloaded the source from python official site, and then extract it.
[root@test python]# curl -O https://www.python.org/ftp/python/3.7.1/Python-3.7.1.tgz % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed100 21.7M 100 21.7M 0 0 850k 0 0:00:26 0:00:26 --:--:-- 959k[root@test python]# tar -zxf Python-3.7.1.tgz[root@test python]# cd *[root@test Python-3.7.1]# mkdir mypython
Now we start to configure it to a predefined destination.
[root@test Python-3.7.1]# ./configure --prefix=$HOME/python/mypython...checking MACHDEP... checking for --without-gcc... nochecking for --with-icc... nochecking for gcc... nochecking for cc... nochecking for cl.exe... noconfigure: error: in
/root/python/Python-3.7.1’:configure: error: no acceptable C compiler found in $PATHSee config.log' for more details
This configuration error seemed to be related to missing or found no acceptable C compilers in $PATH. Since we are using a minimal version of Linux, it doesn’t have gcc (GNU Compiler Collection) package installed, which is a proper and suitable C compiler for make.
And what is $PATH? PATH is an environment variable on Unix-like operating systems, DOS, OS/2, and Microsoft Windows, specifying a set of directories where executable programs are located. In general, each executing process or user session has its own PATH setting.
Since the installer found no C compiler in $PATH, a string that puts conventional binary directories together, such as /usr/bin, /usr/local/bin or /sbin, etc. to compile the source, it threw “Configure: Error: no acceptable C compiler found in $PATH” to alert users to fix the problem.
So next, I install the proper C compiler gcc by the following command and then it will appear in $PATH afterwards:
[root@test ~]# yum -y install gcc...
In fact, there’s a better way to pass all dependency issue like “no acceptable C compiler found in $PATH” during whole installation. That is to say, you may need all essential development tools including all kinds of supportive and acceptable compilers.
[root@test ~]# yum -y groupinstall "Development Tools"...
Now we can try it again and finish the rest of the installation.
[root@test Python-3.7.1]# ./configure --prefix=$HOME/python/mypython...[root@test Python-3.7.1]# make...[root@test Python-3.7.1]# make test...[root@test Python-3.7.1]# make install...ModuleNotFoundError: No module named '_ctypes'make: *** [install] Error 1
There came a message that complained about “No module named ‘_ctypes’”. Now we have a library dependency problem.
libffi-devel is Required
Even if the configuration is done well and C compiler is now acceptable in $PATH, we found another issue about C compiler interface occurred during make install. In addition to C compiler, we need libffi-devel package to act as the foreign function interface for C compiler to provide ctypes and rest modules.
[root@test Python-3.7.1]# yum -y install libffi-devel...
Let’s do it again. This time, make install found an acceptable C compiler in $PATH and worked well.
[root@test Python-3.7.1]# make install...Looking in links: /tmp/tmp8b7ksh64Collecting setuptoolsCollecting pipInstalling collected packages: setuptools, pipSuccessfully installed pip-10.0.1 setuptools-39.0.1
I don’t see “Configure: Error: no acceptable C compiler found in $PATH”. Do you?
GeoIP Installation via PECL
Same error “no acceptable C compiler found in $PATH” occurred when installing geoip via PECL utility.
[root@test ~]# pecl install geoip-1.1.1...checking for cc... nochecking for gcc... noconfigure: error: in
/var/tmp/pear-build-rootS2pmRo/geoip-1.1.1’:configure: error: no acceptable C compiler found in $PATHSee config.log' for more detailsERROR:
/var/tmp/geoip/configure --with-php-config=/usr/bin/php-config’ failed`
Although PECL is not a C compiler, it’s a utility that can assist PHP packages to be installed. During the package installation, PECL need C compiler to make source. Eventually, it cannot find any C compiler in conventional $PATH.
Same error occurred again. So I installed development tools, a package group just like the above solution in python installation.
Let’s try again.
[root@test ~]# pecl install geoip-1.1.1downloading geoip-1.1.1.tgz ...Starting to download geoip-1.1.1.tgz (13,004 bytes)...checking for geoip files in default path... not foundconfigure: error: Please reinstall the geoip distributionERROR:
It still failed, but it’s not about “no acceptable C compiler found in $PATH”. It’s about geoip-1.1.1.
geoip-1.1.1 is Required
No such “Configure: Error: no acceptable C compiler found in $PATH” this time. But we have another error which told us to install a proper package called geoip-devel first.
[root@test ~]# yum -y install geoip-devel...
Then I tried to make it right again.
[root@test ~]# pecl install geoip-1.1.1downloading geoip-1.1.1.tgz ...Starting to download geoip-1.1.1.tgz (13,004 bytes)...Build process completed successfullyInstalling '/usr/lib64/php/modules/geoip.so'install ok: channel://pecl.php.net/geoip-1.1.1configuration option "php_ini" is not set to php.ini locationYou should add "extension=geoip.so" to php.ini
This time, we’re good.
As for Debian or its variants, you can run the equivalent command: sudo aptitude install build-essential
to solve the configuration error.
In conclusion, the lesson I learned from this error “no acceptable C compiler found in $PATH” is that we should know and install all dependencies of configuration packages before installing python and geoip. In this case, we need an acceptable C compiler found in $PATH in order to make install all kinds of sources.
