Managing SSH Keys With WHM
To manage SSH keys, follow this guide as it will show you how to add, import and manage them with your server. SSH keys will be divided into two types: public and private.
Step 1: Log in to your WHM account
Step 2: Click on the Security Center button
Step 3: Click on Manage root’s SSH Keys button
You can equally search for security center in the WHM search box in the top-left, and then click on Manage root’s SSH Keys under the available options within the column
How Do I Generate A New SSH Key?
This section will show you how to generate a new key, public or private.
Step 1 : Click the Generate New Key button
Step 2: Create a unique key name in the Key Name text box
Step 3: Enter a password for the key name if you wish
- 3a : Confirm password, if necessary
- 3b: You can use the Password Generator to generate a random password
Step 4: Pick your preferred Key Type
- RSA – Faster verification times
- DSA – Faster generation and signing times
Step 5: Select your preferred Key Size
Higher the size, the better the security, but the slower the authentication speed
Step 6: Click the Generate Key button
How Do I Import An SSH Key?
Step 1: Click the Import Key button
Step 2: Create a custom key name in the first text box
a. When you create a custom key name, the SSH key must be specified when you log in to the server b. To be specific you’ll need to run the following command:
ssh user@example -i /root/.ssh/key_name
Step 3: Enter the Private key passphrase in the text box if you’re using a PPK (PuTTY Key Generator) file
Step 4: Paste the Private key into the box
Step 5: Paste the Public key into the box
Step 6: Click the Import button
How Do I Manage The Keys?
You can manage the keys you create and import through the Public and Private Keys tables at the bottom of the Manage root’s SSH Keys section. You can perform the following actions: Delete Key, View/Download Key and Manage Authorization.
Related Articles
- cPanel and WHM Overview
- Definition of WHM Functions
- Selecting A PHP Handler In WHM
- Most Recommended WHM Tweaks
Posted in Security CenterTagged ssh key whm
