How to Install Durex Kodi Build
The following step-by-step guide will show you how to install Durex Kodi Build.
The Durex Kodi Build offers four servers to choose from. If you find one does not work, try the others until the Build downloads. Durex is listed as one of the Best Kodi Builds available as determined by the TROYPOINT Community.
TROYPOINT suggests resetting Kodi to default settings prior to installing any build for best results. See below how to reset Kodi on your preferred device.
Goto link on the top of this post for the full website and instructions.
TROYPOINT Rapid App Installer
Install the best streaming apps & tools in a matter of minutes
Works on all Anroid-powered devices such as Fire TV/Stick, NVIDIA SHIELD, MI BOX, TV boxes, phones, and tablets
Applications updated on a regular basis to ensure you are getting the best
Receive the weekly TROYPOINT Newsletter with tips, tricks, tutorials & more
https://troypoint.com/troypoint-rapid-app-installer-reg
Follow the steps below to install Durex Build on your Kodi device.
Launch Kodi
Click the Settings icon Kodi Settings Icon
Click System settings
Hover over Add-ons menu item and turn on Unknown sources if not already on
Click back on remote to go back to System page
Select File Manager
Click Add source
Click
Type the following url exactly how it is listed here – http://drxbld.com/wiz and click OK
Highlight the box under the source that you just typed in and enter a name for this media source, type durex or any other name you would like to identify this source as and click OK
Click your back button on remote or keyboard until you are back at the Kodi home screen
Click Add-ons menu item
Choose the small “open box” icon at top left side of page under the “Add-ons heading” Install Kodi Addon
Click Install from zip file
Choose Durex or other name you assigned the media source in previous step
Click plugin.program.drxwizard.zip
Wait for Durex Wizard Add-On message to appear (This may take up to a minute)
Click Dismiss
Enable any Settings you would like on your build
Click Ignore
Return to Main Menu
Go To Add-Ons
Program Add-Ons
Durex Wizard
Click Builds
Select your preferred Build
Click Standard Install
Click Yes, Install
Once downloaded, Kodi will shut down – if not, unplug power cord on device for 15 seconds and plug back in
Restart your Kodi Program
The Durex Kodi build is now installed!
Durex Kodi Build Features
Upon completion of the build being installed, please allow enough time for add-ons to update and menus to build. While these are installing, you will see messages in the bottom right of your screen. Due to the size of this build, this may take up to 5 minutes.
In addition to an updated home screen with Durex, you will also have some awesome pre-loaded add-ons. Some of these include: Not Sure, WolfPack, Nemesis, Now Music, SubZero, StreamHub, Maverick TV, Gears TV, StreamsRUs, BoB Unleashed, GoodFellas, Neptune Rising, Jukebox Hero, Kidz Corner, Limitless IPTV, Mobdina, Placenta, Planet MMA, Oculus, SpinzFlix, The Pyramid, and many more.
Durex has their own IPTV Service that is available within this build. This is a paid service and is already available upon installation. Along with the paid IPTV Services offered, Durex also has some free options. With so many choices, it is easy to see why Durex has become such a popular Kodi Build.
Liquid Layer Networks - Global SSD Hosting
