Latest OTA knocking hotspots offline
Nov 30, 2019
The prior update, shipped this morning, has had some unintented consequences. Because of a change in an init script, a latent race condition in the configuration of the WiFi interface has caused some Hotspots to be unable to connect to WiFi. Whether a Hotspot is affected depends on what firmware version it was running when it was initially configured for WiFi. Hotspots on Ethernet should not be affected.
If your Hotspot is showing ‘needs attention’ and has a greenish/yellow LED color, you are likely affected.
We have analyzed the problem and there are 2 known fixes:
- Re-configure the wifi credentials on the hotspot
- Boot the previous firmware
To boot the previous firmware, use the following procedure:
- Unplug the power
- Press down the black pairing button on the side of the Hotspot
- Reconnect the power while holding down the black pairing button
- While holding down the button, wait for the status LED to light up, then wait an additional 10 seconds
- Release the button
This will cause the Hotspot to boot the previous firmware where the race condition was far less likely and the Hotspot will be able to use its configured Wifi credentials.
An OTA with a permanent fix is in testing and will be deployed once it is confirmed to work as intended. We apologize for the inconvienience.
Helium Engineering Blog
Updates, straight from the cauldron of engineering.
Curated by: Helium.city | The Peoples Network Helium.com
Global Hosting Services: https://www.ParagonHost.net
