Forcing the domain to serve securely using HTTPS (for any site)
What to change in the examples below?
The examples below can be entered into your .htaccess file exactly as shown.
Only if the example contains a URL in bold should you change that to your actual URL. For example, if you see the domain ‘example.com’, change this to your own domain name.
The following forces any http request to be rewritten using https. For example, the following code forces a request to http://example.com to load https://example.com. It also forces directly linked resources (images, css, etc.) to use https:
RewriteEngine On RewriteCond %{HTTPS} !=on RewriteRule ^(.*)$ https://%
{HTTP_HOST}%{REQUEST_URI} [L,R=301,NE]
If this isn’t working for you, first check your line endings. Copy/paste from your web browser into a text editor may not work right, so after pasting into your text editor you should delete each line break and add it back in (line break = return key).
