Menu / Status will show current allocation LAN IP Address.
Browse to that address
User: admin
Pass: 23646 (which spells “admin” on keypad)
Technical Note: Default admin Web UI login for FortiFone . The following factory default login can be used in order to gain Web UI Management access to most FortiFone models and firmware versions. The password above spells ’ admin ’ on the keypad
