256-bit AES Encryption [PRO]
Encrypt Mac backups with up to 256-bit strong keys on the source side. All data sent to the cloud is encrypted using the SSL protocols to protect while it is in transit.
Compression [PRO]
Reduce data overhead, decrease storage costs, aid bandwidth and accelerate backup completion with optional compression.
No Storage Limits [PRO]
Data volume you can manage with MSP360™ Backup is unlimited.MSP360™ doesn’t offer storage, you need to buy from storage providers separately.
Scheduled Backup
Build flexible Mac backup schedule for files and folders.
Incremental Backup
Backup only new and modified files after the initial full backup.
Block-Level Backup
Backup only modified or new portions of files to add them to existing online data pool.
Command Line Interface
Use the Command Line Interface to integrate backup with your own routines.
Retention Policies
Set up retention options to enable automated deletion of outdated data from your storage. Keep only actual versions of your backups.
Email Notifications
Set up customizable email notification feature to track each run of your Mac cloud backup and restore plans remotely.
Local Backup
Backup Mac to cloud storage of your choice or set up local backup if you want to send only a subset of your data to the cloud and keep the rest on your local backup storage.
Network Locations Backup
Back up your network locations including network shares, NAS devices, mapped drives, etc.
Symlinks Support
Maintain correct file structure and backup only what you need.
