If you are unable to send email, you first should verify that all information is correct in your email client. Below are the general email configuration settings.
Check your Email settings
| Incoming Server | mail.YourDomain.com |
| Outgoing Server | mail.YourDomain.com |
| Username | Your full e-mail address |
| Password | Your e-mail account password |
| Incoming Port | POP3 110 or IMAP 143 |
| Outgoing Mail server (SMTP) Port | 587 |
| SSL | NO |
| SMTP Authentication | Required |
| Secure Authentication or SPA | Needs to be turned off |
Check that Port 25 is not blocked
Some Internet Service Providers (ISPs) may block the normal sendmail port 25, so the easiest way is to contact them and ask for the Outgoing Server SMTP setting which you will then replace (Outgoing Server: mail.yourdomain.com) with above.
Alternatively if your ISP is blocking port 25 you can try port 465 or 587 instead of 25.
Here is a simple test you can find out if this is the case.
Please note that on newer versions of Windows, Telnet is not enabled automatically. You can turn on Telnet in your computer’s Control Panel by clicking on Programs and Features, then clicking on Turn Windows features on or off and ticking the box nex to Telnet.
- Windows users can access this via start > run > cmd . Mac users can use the Terminal application.
- Enter telnet mail.domain.com 25 (replace domain.com with your own domain name).
If you just see a blank screen then your ISP provider is blocking port 25.
If you log in to your Webmail you will be able to send and receive email from anywhere in the world.
