It is necessary to have an encoder or other broadcasting automation solution in order to go live on your Live365 station. Luckily, many programs are compatible with the Live365 platform. Below are 12 of the most used applications with Live365 stations.
AltaCast
AltaCast is a streaming software supported by Windows. It runs as a standalone encoder but also works with various media players compatible with Winamp plugins. AltaCast is one of the preferred encoders for RadioDJ (mentioned below). Cost: Free.
Audio Hijack
Audio Hijack was recommended by the folks at Nicecast after it retired in early 2018. It’s available on a Mac OS and has both a free version or an enhanced version for purchase. Cost: Free or $59+. d
BUTT (Broadcast Using This Tool)
BUTT can be configured on Mac, Windows, and Linux. If you plan on doing live shows with voice, BUTT may just be the software for you. Cost: Free.
LadioCast
LadioCast runs on a Mac OS. Users like LadioCast to mix their mic with their music. This software has four inputs and four outputs. Cost: Free.
MegaSeg
MegaSeg is supported by a Mac OS. Some key features are the option to choose from auto crossfade or manual control, a request list pop-up, and voice-overs. Cost: $99+.
Curated by: Rock Radio 365 | Ear Candy 24.7
