2015
On the AP110, AP120, AP330, and AP350, the status LED colors indicate the following states:
Dark : There is no power or the status indicator is disabled.
Blue (solid) : The device is booting up or there is no backhaul link; (flashing) the device is shutting down.
Green : The default router is through the backhaul Ethernet interface, but not all conditions for normal operations (white) have been met.
Yellow : The default route is through a backhaul Wi-Fi interface, but not all conditions for normal operations (white) have been met.
White : The device is powered on and the firmware is operating normally; that is, the AP has made a CAPWAP connection to HiveManager.
Purple : A new image is being loaded from HiveManager.
Orange : An alarm indicating the firmware or hardware issue has occurred.
