Q: 3dCart.com Difference between HTML5 and Core Templates
A: HTML5 themes and CORE are both SEO Friendly. The main different is CORE is built on Bootstrap framework (a more known library of code) and the HTML5 does not. This means the CORE is able to load scripts last, whilte HTML5 usually loads them first. You are looking at a 1-2 second more for page load. Otherwise, you would be fine to continue with HTML5.
