Durable high performance,
redesigned with
the photographer in mind
Superior performance redesigned to meet photographers needs.
A broader world of photography.
A deeper level of expression.
Thanks to the high-performancetelephoto zoom
that feels right in every situation.
A professional 300mm F2.8 telephoto with powerful zoom capability,
this lens allows complete customization, so you can tackle tough situations with ease.
Offering excellent image expression and a low F-number, the large-aperture 300mm F2.8 lens is a favorite piece of equipment among professional photographers. With the idea of taking this spec to the next level with powerful zoom capability, SIGMA developed the 120-300mm F2.8 zoom lens. It is difficult to compose shots with traditional 300mm lenses. In the case of sporting events, performances on stage and other situations in which it is difficult to change your position, you often lose the desired shot in the process of changing lenses. A large-aperture 120-300mm F2.8 zoom lens, however, eliminates the need for most lens changes, allowing the photographer to adjust zoom and easily achieve the desired framing. Even in the most difficult of situations, this lens truly empowers photographic expression.
Embodying the concept of our Sports line of lenses,
this lens responds directly to photographers’
needs with outstanding action-capture performance.
In addition to the highest levels of optical performance and photographic expression, SIGMA’s new Sports line of lenses offers the kind of action-capture performance that precisely executes the intentions of the photographer. Uncompromising optical performance and photographic expression allow the photographer to shoot fast-moving and distant subjects, while exceptional functionality makes possible excellent shots even in the most challenging of situations. The SIGMA 120-300mm F2.8 DG OS HSM|Sports is the first lens to embody the concept of the Sports line. Fully customizable, it allows the photographer to create his or own specification. It is an ideal choice for photographing many different subjects; birds, wild animals, airplanes, motorsports, and even portraits. And SIGMA’s exclusive software makes the lens extremely easy to customize.
