Plugin errors affect WordPress in various ways. In the best possible way, an error message will display in the admin area that indicates the plugin causing the problem. In worse cases, errors will be displayed on your website, which may affect your branding.
Errors can occur after installing and updating plugin or after updating WordPress. The latter indicates that your plugin is not compatible with the current version of WordPress.
To fix plugin error, simply locate the plugin causing the problem and deactivate it. As mentioned, you can locate the faulty plugin as displayed in the error message. However, if the error message does not state the faulty plugin, you can manually locate the issue by deactivating all plugins, reactivating each one at a time while checking your WordPress site - whichever clashes with your site is the odd one out.
How to Deactivate Faulty Plugin
To disable faulty plugin, follow the steps below.
- Open a browser.
- Enter YourWordPressDomainName/wp-admin on your browser.Note: Replace YourWordPressDomainName with your actual website.
- Enter username and password, and click Log In.
- On the left-hand corner, click Plugins.
- Search for the faulty plugin, and click Deactivate.
- Click Apply.
How to Manually Locate Faulty Plugin
To manually locate faulty plugin, follow the steps below.
- Open a browser.
- Select all plugin, then from the Bulk Action menu at the top of the page, select Deactivate.
- Click Apply.Important Note: If the error remains after deactivating all plugins, then the plugin is not causing error.
- Enable plugin one at a time by clicking Activate below the plugin’s name.
- Check your WordPress site for errors.
- Repeat steps 7 & 8, until you find the faulty plugin.
When you locate the plugin causing the error, deactivate it.
You may contact plugin developer to inform them about the issue.
Congratulations! You have just fixed WordPress plugin error.
