https://community.sophos.com/kb/en-us/124377
Sophos Endpoint Defense: How to recover a tamper protected system
124377
20 Jun 2019
62 people found this helpful
Overview
This article describes how to recover a tamper protected system if the tamper protection password is lost and the client cannot receive a new policy with a known password.
Applies to the following Sophos products and versions
Sophos Endpoint Security and Control
Central Endpoint Advanced 11.5.11
Central Endpoint Standard 11.5.11
What to do
Note : Remember to do a backup of the registry before attempting these procedures.
Managed by Sophos Enterprise Console
- Boot the endpoint or server in Safe Mode .
- Click Start followed by Run then type
services.msc
- Right-click the Sophos Anti-Virus service then Properties .
- Set the Startup type to Disabled then click the OK button.
- In Run , type
regedit.exe
then click the OK button. - Go to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Sophos Endpoint Defense\TamperProtection\Config
and set the Value data to0
for SAVEnabled and SEDEnabled . - Set the Value data of Enabled to
0
in the following:
- 32-bit:
HKEY_LOCAL_MACHINE\SOFTWARE\Sophos\SAVService\TamperProtection
- 64-bit:
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sophos\SAVService\TamperProtection
- Enhanced Tamper Protection will now be disabled after you boot the endpoint or server in normal mode.
Managed by Sophos Central
Starting 20th January 2018, the Tamper Protection passwords can now be retrieved for deleted endpoints and servers from within Sophos Central. Follow the steps below to obtain this information:
- Log in to Sophos Central.
- Access Logs & Reports > Recover Tamper Protection passwords .
- Click on View details to expand the password(s) that has been set on the endpoint or server. The password at the top of the list is the most recent. This password can be used to authenticate on the local endpoint or server, allowing access to the Settings and the option to disable Tamper Protection .
Note: The report will display endpoints and servers that have been deleted over the previous 60 days. For release, the start date for displaying any deleted endpoints and servers is 09th December 2017.
If you do not have access to Sophos Central, perform the following steps to disable the Enhanced Tamper Protection:
services.msc
- In Run , type
regedit.exe
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Sophos MCS Agent
and set the Value data of Start to0x00000004
Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Sophos Endpoint Defense\TamperProtection\Config and set the Value data of SAVEnabled and SEDEnabled to 0.
0
in the following:
- 32-bit:
- 64-bit:
Registry keys
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Sophos\SavService\TamperProtection
