http://simplybonding.com/overview.html
SimplyBonding simplifies SD-WAN. We do everything for you.
If you have a Peplink Device that support’s Speed Fusion, then you can use SimplyBonding.com to truly “bond” all of your 3G / 4G Cell connections together for the SUM of all connection speeds. Without the use of SimplyBonding, then you will only Link Balance between your conections VS bonding them together.
This is true of any link balancing solution out there.
SimplyBonding is a hosting service that allows you to bond multiple internet connections into one super fast, super reliable, unbreakable connection with minimal equipment and setup.
Many routers support “failover,” which allows them to fail over to a secondary connection when one internet connection goes down, but you lose the connection during the switchover (and then you’ll have the same problem when the primary connection comes up again and it switches back). Failover also doesn’t aggregate the connections to make them faster or more reliable. Load Balancing routers can split the traffic load amongst multiple internet connections, but they do not aid in reliability or increase speed. Failover and load balancing are useful features, but they are NOT the same as bonding.
A bonded internet connection solves all of these problems.
A bonded internet connection takes multiple internet connections and bonds them into one super fast/reliable connection. Unlike failover or load balancing, a bonded connection takes multiple internet connections and COMBINES them. If you have 3 internet connections that are bonded together and one goes down, your connected devices and apps will never know there was a failure - even apps that maintain persistent connections!
The downside to a bonded internet connection has been that it’s very costly and hard to configure - until now…
What is it? - SimplyBonding is a hosting service that allows you to bond multiple internet connections into one super fast, super reliable, unbreakable connection with minimal equipment. Unlike failover or load balancing, a bonded connection takes multiple internet connections and COMBINES them. If you have 3 internet connections that are bonded together and one goes down, your connected devices and apps will never know there was a failure - even apps that maintain persistent connections! How does it work? - SimplyBonding uses Peplink’s Speedfusion technology to bond multiple 3G, 4G, DSL, or cable connections into one fast/reliable/unbreakable connection.
Utilizing Speedfusion typically requires a Peplink router on both ends of the connection - one at the location where you need the bonded connection, and another at another location with a high-speed internet connection to bond the connections and send the data back to the primary location via VPN. SimplyBonding eliminates the need for this dual-router setup. SimplyBonding requires just ONE router, which will be configured to connect to our hosted service - WE handle the bonding and VPN for you! For more information on how you can get online with unbreakable, always-on connectivity.
What is Speedfusion? - click the “v” symbol below right of the box to toggle dialog expansion.
Call us Toll-Free: 1-866-3GSTORE (+1 866-347-8673)
Alternate phone line: 847-462-4004
Fax number: 847-829-3885
Our sales phone hours are Monday - Friday 9am to 6pm CST
Our tech support phone hours are Monday - Friday 9am to 5pm CST
Warehouse will-call pickup hours: Monday - Friday 9am - 4:30pm CST
Email Us:
Product Questions? -> sales@3Gstore.com
B2B Sales? -> corpsales@3Gstore.com
Customer Support? -> support@3Gstore.com
bonding, 3g, 4g, bandwidth, speed fusion, hosted, provider, carrier, service provider, link, balance, aggregation, load balance, service, connection, peplink, mobile, routers, route.
