Product Packaging: Standard Packaging
Recommended Use: PC multimedia
Headphones Type: Headset - mono
Headphones Form Factor: On-ear - vertical
Single-ear USB business headset: Ideal for having an open ear to your surroundings on desktop calls
Plug-and-play compatibility: Works with PC, Mac, Microsoft Lync, Cisco, Skype and most leading UC platforms
Enterprise-quality audio at an affordable entry level price: Business-grade Wideband Audio, Digital Signal Processing (DSP) and noise-cancelling boom mic for crystal-clear conversations
Comfort and control: Durable padded headband and ear cup. Convenient Inline Call Controls and Incoming Call Indicator light
This business product ships in brown box with no retail packaging
Logitech UC Audio
The professional line of Logitech UC headsets and audio accessories is built by 30+ years of PC experience mixed with decades of audio expertise. With enterprise-quality performance, plug-and-play compatibility and intuitive user-friendly designs, Logitech UC Audio is engineered to help you and your team get things done.
Logitech USB Headset Mono H570e
Clear, comfortable communication made affordable
Improve communication and collaboration in your workplace with a UC headset that delivers a feature set unmatched in the entry-level price category*. From professional quality Digital Signal Processing to broad compatibility with PC, Mac and most leading UC platforms, H570 makes effective business conversations plug-and-play easy.
Includes audio features similar to competitive products plus adjustable padded headband and premium replaceable leatherette ear pads.
- High quality wideband audio and noise-cancelling boom mic
- Comfortable, lightweight design
- Convenient on-cord call controls
Seamless UC compatibility
H570e is certified to integrate seamlessly with most business-grade Unified Communications platforms. The headset is optimized for Microsoft Lync, Cisco compatible** and Skype certified.
** Visit Logitech website for the latest version. #### Long-wearing comfort
The premium leatherette ear pad, adjustable padded headband and lightweight design provide an ultra- comfortable fit. The headband is metal reinforced for extra strength and durability. The ear pad can be easily cleaned or replaced without having to buy a whole new headset. #### Noise-cancelling boom mic
Advanced noise cancellation eliminates distracting background noise so callers hear you clearly. Easily rotate the boom to just the right position for best voice pick up.
Digital Signal Processing and a dynamic equalizer precisely adjust mic and speaker audio for best sound quality. Hear and be heard in true wideband audio for a more natural and true-to-life listening experience. And Logitech Sound Protection helps protect your ears against sounds above 115dBA (EN60950-1 compliant). #### Convenient call controls
On-cord controls give you quick access to volume up/down, microphone mute and call answer/end***. Plus, a flashing Incoming Call Indicator light provides a convenient visual cue to answer the phone****.
***With Microsoft Lync and Cisco deployments. Visit Logitech website for the latest version. Works with Skype using plug-in. Select the appropriate product and download from Logitech website.
****With Microsoft Lync, Jabber for Windows 9.7.4 and later deployments; Skype requires a plug-in. Select the appropriate product and download from Logitech website. #### Plug-and-play simplicity
There’s no wireless setup or software to install. Simply plug the USB headset into any Windows PC or Mac and start making clearer hands-free calls right away.
System requirements
- Windows 7, Windows 8 or Windows 8.1 (32-bit or 64-bit)
- Mac OS 10.6 or higher
- Available USB port
Compatible with most leading UC platforms, such as Microsoft Lync, Skype, Cisco Jabber, Cisco IP Compatible**
What’s in the box
Headset
Quick Start Guide/warranty card
