Keyboard Shortcuts and Markdown
Amplenote is all about efficient writing and productive note organization. Many folks find it tedious to switch between mouse and keyboard to make formatting changes. That’s why we have keyboard shortcuts and markdown.
Wait, what’s the difference?
Keyboard shortcuts are the actions you take to turn on or off a setting.
Markdown is a plain text formatting syntax that quickly create rich text in a plain text editor.
Keyboard Commands
Quick Search
WINDOWS
Ctrl-O
MAC
Cmd-O ⌘o
Tab or up/down arrows to navigate menu
Enter/return to select
Esc to close
Formatting Bar
Bold Text
WINDOWS
Ctrl-B
MAC
Cmd-B ⌘b
MARKDOWN
*text*
Italic Text
WINDOWS
Ctrl-I
MAC
Cmd-I ⌘i
MARKDOWN
_text_
Header 1
WINDOWS
Shift-Ctrl-1
MAC
Shift-Ctrl-1 ⇧⌃1
MARKDOWN
# text
Header 2
WINDOWS
Shift-Ctrl-2
MAC
Shift-Ctrl-2 ⇧⌃2
MARKDOWN
## text
Header 3
WINDOWS
Shift-Ctrl-3
MAC
Shift-Ctrl-3 ⇧⌃3
MARKDOWN
### text
Task List
check_box_outline_blank
Task
Task
Task
MARKDOWN
[ ] text
Tab to indent, Shift-Tab to outdent
Ctrl-. or Cmd-. (⌘.) to expand Task Detail panel
Bullet list
Bullet
Bullet
Bullet
MARKDOWN
* text
- text
Numbered list
Item
Item
Item
MARKDOWN
1. text
Note that ordered lists can begin with numbers other than 1
Type in any number
The list continues
And continues
Link and Rich Footnote
WINDOWS
Ctrl-K
MAC
Cmd-K ⌘k
Block Quote
WINDOWS
Shift-Ctrl->
MAC
Shift-Ctrl-> ⇧⌃>
MARKDOWN
> text
Code Snippet
WINDOWS
Shift-Ctrl-`
MAC
Shift-Ctrl-` ⇧⌘`
MARKDOWN
`text`
Code Block
WINDOWS
Shift-Ctrl-\
MAC
Shift-Ctrl-\ ⇧⌃\
MARKDOWN
text
Undo
WINDOWS
Ctrl-Z
MAC
Cmd-Z ⌘z
Redo
WINDOWS
Shift-Ctrl-Z
MAC
Shift-Cmd-Z ⇧⌘z
Note that you can combine inline styling (bold, italic, strikethrough, code snippets, and links/rich footnotes) to block elements (headers, list items, and block quotes).
Here’s an example of inline styling applied
to a block element
And here’s an example of a task with rich footnote
More Formatting Options
Strikethrough
MARKDOWN
~text~
Emoji
MARKDOWN
:emoji-name:
Horizontal Line
MARKDOWN
