Cloud Web Hosting Services by LiquidLayer.net
LiquidLayer.net offers premium web hosting, SSD, Cloud Hosting, VPS & dedicated server solutions with 24/7 support & Mission Critical Uptime
2019-05-23T07:00:00Z
(Ex) Option 66:
Need to convert each byte to HEX, like 192=C0, 168=A8,… so the correct config should be:
set option2 66 ‘C0A8026F’.
http://string-functions.com - On this site, you will find free online tools to perform common string manipulations such as reversing a string, calculating a string’s length or encoding a string!
How-to: Configure DHCP Custom Options on a FortiGate
FortiGate allows you to configure up to six custom DHCP options beyond the standard default gateway, DNS, NTP and domain options.
We’ll go through the steps to configure a DHCP server from scratch and configure the most commonly used options as well as a few custom ones.
The details for this DHCP server will be as follows:
Interface: wifi-interface
Address Range: 192.168.2.100-192.168.2.254
Subnet: 255.255.255.0
Default Gateway: 192.168.2.99
Primary DNS: 192.168.2.99
Secondary DNS: 8.8.8.8
Primary NTP: 192.168.2.99
Domain name suffix: labdomain.local
Option 252: http://myproxy.com:80/wpad.dat (this is the default proxy option)
Option 66: 192.168.2.111 (TFTP option to allow provisioning to unmanaged SIP phones)
Firstly goto the CLI and enter the following to create a new DHCP server.
FORTIGATE80C # config system dhcp server
FORTIGATE80C (server) # edit 0
Now type the following to create the IP range
FORTIGATE80C (3) # config ip-range
FORTIGATE80C (ip-range) # edit 1
FORTIGATE80C (1) # set start-ip 192.168.2.100
FORTIGATE80C (1) # set end-ip 192.168.2.254
FORTIGATE80C (1) # end
Next the following set commands for all the basic options:
FORTIGATE80C (3) # set default-gateway 192.168.2.99
FORTIGATE80C (3) # set netmask 255.255.255.0
FORTIGATE80C (3) # set dns-server1 192.168.2.99
FORTIGATE80C (3) # set dns-server2 8.8.8.8
FORTIGATE80C (3) # set ntp-server1 192.168.2.99
FORTIGATE80C (3) # set domain labdomain.local
FORTIGATE80C (3) # set interface wifi-interface
Now for the custom options. The syntax for custom options on a FortiGate is:
set
An option number is a decimal number (in this instance 252 and 66), while the option itself is the value we want (http://myproxy.com:80/wpad.dat and 192.168.2.111). The thing to note is that the FortiGate require the option to be in hexadecimal, not as a string or digits. So before we can begin, we need to convert the strings into hexadecimal first.
A quick google for ‘string to hexadecimal converter’ will bring up some useful pages. I like to use the one at string-functions.com. Type in the strings you want to convert and save the hexadecimal output.
Note:
I don’t think this opion 66 config would work. Any field that contains an IP address in Bootp vendor options(DHCP options) requires binary data, just like source/destination address field in Ethernet Frame header, not “ascii coded dotted-decimal-notation”. So you need to convert each byte to HEX, like 192=C0, 168=A8,… so the correct config should be:
Global Web Hosting Services Since 2000 | Web Netology
Free Web Hosting for Hostcheetah Blog Readers!
Web Netology
