Fortnet Guest WiFi accounts
https://docs.fortinet.com/document/fortigate/6.0.0/cookbook/694000/guest-wifi-accounts
Guest WiFi accounts
In this recipe, you create temporary guest accounts that can connect to your WiFi network after authenticating using a captive portal. To make management easier, you also create a separate administrative account that can only be used to manage guest accounts.
This example uses a FortiAP in Tunnel mode to provide WiFi access to guests. For information about configuring the FortiAP, see Setting up WiFi with FortiAP.
