FortiVoice Audio Files
16 bit PCM mono wave file with sample rate of 8000 hz.
ShoreTel Audio Files
RIFF (little-endian) data, WAVE audio, ITU G.711 mu-law, mono 8000 hz.
Wonderful site to convert voice over / audio files to correct format for most VoIP Ip-PBX Phone Systems
G711 File Converter
This free tool will convert just about any DRM-free media file into audio that’s compatible with BroadWorks or Asterisk Music on Hold and IVR Announcements.
Output Format
BroadWorks Classic (8Khz, Mono, u-law)
BroadWorks 17sp4+ SD (8Khz, Mono, 16-Bit PCM)
BroadWorks 17sp4+ HD (16Khz, Mono, 16-Bit PCM)
Asterisk Standard (8Khz, Mono, 16-Bit PCM) * Best for FortVoice IP PBX by Fortinet
Asterisk HD (16Khz, Mono, G.722)
Asterisk G.729 (8Khz, Mono, G.729)
Asterisk RAW (8Khz, Mono, RAW)
