Q: How to embed video to home page using a 3dcart.com template
A: You’ll want to edit the home.html template and add the embedded code to have the video display. You’ll want to go over to settings > design > theme & styles > edit template (HTML) and locate the home.html . If it is not there at first glace, you’ll want to go to the common-html5 in the drop down. If you don’t know html coding, you can purchase the service to edit the home page over at mywebmasters.3dcart.com
You may also, Login to 3dcart, then browse in another tab to your website, Edit tools will show on the bottom of the site, where you can edit / home page which will provide WYSIWYG or code edits of Header and Footer.
