Converting Unsupported Audio Files to WAV
On this topic
Convert to Wav with the 3CX Online Audio Converter
Manually Convert an Audio File
Upload Converted Audio Files to 3CX
3CX allows you to import audio files in this format to use as the system prompts:
- Format: WAV
- Channel: Mono
- Bit rate: 8 kHz
- Sampling: 16 bit
You need to convert to this format any prompts for IVR, Queues and custom system prompt sets.
Automatically convert an audio file to the appropriate format with the 3CX Online Audio Converter:
